enable snmp community
enable snmp community [encrypted enc_community_name | community_name |alphanumeric-community-string | hex hex_community_name
Description
Enables SNMP community strings.
Syntax Description
encrypted Community name is encrypted.
enc_community_name Encrypted community name.
community_name Community name in ASCII format.
hex Provide value in hexadecimal.
hex_community_name Community name in hexadecimal.
alphanumeric-community-string Specifies the SNMP community string name.
Default
N/A.
Usage Guidelines
This command allows the administrator to enable an snmp community that has been disabled. It sets the row status of the community to Active.
The following command enables the community string named extreme:
enable snmp community extreme
The hex keyword and hex_community_name variable were added in ExtremeXOS 15.6.
Platform Availability
